cross-env
7.0.3 β€’ Public β€’ Published
cross-env πŸ”€
Run scripts that set and use environment variables across platforms
🚨 NOTICE: cross-env still works well, but is in maintenance mode. No new features will be added, only serious and common-case bugs will be fixed, and it will only be kept up-to-date with Node.js over time. Learn more
Build Status Code Coverage version downloads MIT License All Contributors PRs Welcome Code of Conduct
The problem
Most Windows command prompts will choke when you set environment variables with NODE_ENV=production like that. (The exception is Bash on Windows, which uses native Bash.) Similarly, there's a difference in how windows and POSIX commands utilize environment variables. With POSIX, you use: $ENV_VAR and on windows you use %ENV_VAR%.
This solution
cross-env makes it so you can have a single command without worrying about setting or using the environment variable properly for the platform. Just set it like you would if it's running on a POSIX system, and cross-env will take care of setting it properly.
Installation
This module is distributed via npm which is bundled with node and should be installed as one of your project's devDependencies:
npm install --save-dev cross-env
WARNING! Make sure that when you're installing packages that you spell things correctly to avoid mistakenly installing malware
NOTE : Version 7 of cross-env only supports Node.js 10 and higher, to use it on Node.js 8 or lower install version 6 npm install --save-dev cross-env@6
Usage
I use this in my npm scripts:
  "scripts": {
    "build": "cross-env NODE_ENV=production webpack --config build/webpack.config.js"
Ultimately, the command that is executed (using cross-spawn) is:
The NODE_ENV environment variable will be set by cross-env
You can set multiple environment variables at a time:
  "scripts": {
    "build": "cross-env FIRST_ENV=one SECOND_ENV=two node ./my-program"
You can also split a command into several ones, or separate the environment variables declaration from the actual command execution. You can do it this way:
  "scripts": {
    "parentScript": "cross-env GREET=\"Joe\" npm run childScript",
    "childScript": "cross-env-shell \"echo Hello $GREET\""
Where childScript holds the actual command to execute and parentScript sets the environment variables to use. Then instead of run the childScript you run the parent. This is quite useful for launching the same command with different env variables or when the environment variables are too long to have everything in one line. It also means that you can use $GREET env var syntax even on Windows which would usually require it to be %GREET%.
If you precede a dollar sign with an odd number of backslashes the expression statement will not be replaced. Note that this means backslashes after the JSON string escaping took place. "FOO=\\$BAR" will not be replaced. "FOO=\\\\$BAR" will be replaced though.
Lastly, if you want to pass a JSON string (e.g., when using ts-loader), you can do as follows:
  "scripts": {
    "test": "cross-env TS_NODE_COMPILER_OPTIONS={\\\"module\\\":\\\"commonjs\\\"} node some_file.test.ts"
Pay special attention to the triple backslash (\\\) before the double quotes (") and the absence of single quotes ('). Both of these conditions have to be met in order to work both on Windows and UNIX.
cross-env vs cross-env-shell
The cross-env module exposes two bins: cross-env and cross-env-shell. The first one executes commands using cross-spawn, while the second one uses the shell option from Node's spawn.
The main use case for cross-env-shell is when you need an environment variable to be set across an entire inline shell script, rather than just one command.
For example, if you want to have the environment variable apply to several commands in series then you will need to wrap those in quotes and use cross-env-shell instead of cross-env.
  "scripts": {
    "greet": "cross-env-shell GREETING=Hi NAME=Joe \"echo $GREETING && echo $NAME\""
The rule of thumb is: if you want to pass to cross-env a command that contains special shell characters that you want interpreted, then use cross-env-shell. Otherwise stick to cross-env.
On Windows you need to use cross-env-shell, if you want to handle signal events inside of your program. A common case for that is when you want to capture a SIGINT event invoked by pressing Ctrl + C on the command-line interface.
Windows Issues
Please note that npm uses cmd by default and that doesn't support command substitution, so if you want to leverage that, then you need to update your .npmrc to set the script-shell to powershell. Learn more here.
Inspiration
I originally created this to solve a problem I was having with my npm scripts in angular-formly. This made contributing to the project much easier for Windows users.
Other Solutions
  • env-cmd - Reads environment variables from a file instead
  • @naholyr/cross-env - cross-env with support for setting default values
Issues
Looking to contribute? Look for the Good First Issue label.
πŸ› Bugs
Please file an issue for bugs, missing documentation, or unexpected behavior.
See Bugs
πŸ’‘ Feature Requests
This project is in maintenance mode and no new feature requests will be considered.
Learn more
Contributors ✨
Thanks goes to these people (emoji key):
Kent C. Dodds
πŸ’» πŸ“– πŸš‡ ⚠️
Ya Zhuang
πŸ”Œ πŸ“–
James Harris
πŸ“–
compumike08
πŸ› πŸ“– ⚠️
Daniel RodrΓ­guez Rivero
πŸ› πŸ’» πŸ“–
Jonas Keinholz
πŸ› πŸ’» ⚠️
Hugo Wood
πŸ› πŸ’» ⚠️
Thiebaud Thomas
πŸ› πŸ’» ⚠️
Daniel Rey LΓ³pez
πŸ’» ⚠️
Amila Welihinda
πŸš‡
Paul Betts
πŸ› πŸ’»
Turner Hayes
πŸ› πŸ’» ⚠️
Suhas Karanth
πŸ’» ⚠️
Sven
πŸ’» πŸ“– πŸ’‘ ⚠️
D. NicolΓ‘s Lopez Zelaya
πŸ’»
Johan Hernandez
πŸ’»
Jordan Nielson
πŸ› πŸ’» ⚠️
Jason Cooke
πŸ“–
bibo5088
πŸ’»
Eric Berry
πŸ”
MichaΓ«l De Boey
πŸ’»
Lauri Eskola
πŸ“–
devuxer
πŸ“–
Daniel
πŸ“–
This project follows the all-contributors specification. Contributions of any kind welcome!
Note: this was added late into the project. If you've contributed to this project in any way, please make a pull request to add yourself to the list by following the instructions in the CONTRIBUTING.md
LICENSE
MIT
Package Sidebar
Install
npm i cross-env
Weekly Downloads
8,980,138
Version
7.0.3
MIT
Unpacked Size
29.1 kB
Total Files
10
Last publish
Collaborators
  • kentcdodds
